My only concern at this time is the oil pressure is not where it use to be, I put in a nos oil pump from Midwest-Bayless during the rebuild. The pressure was only around 20lbs (a little less than a quarter on the gauge) at idle and to about 45lbs at 4k rpms. I primed the motor before firing him up and got good oil in the cam towers. The old oil pressure was 35lbs at idle and 55lbs when normal driving. Is this a bit low? Do I need to be worried?
At any rate it is awesome to hear him fire up. Any advice on breaking him in would be welcomed. Have a great day.
