air fuel ratio meter DIY
dinghyguy
Your car is a: 1981 spider
Post by dinghyguy »
So, has anyone built their own AFR setup? If so what did you use? where did you install the oxygen sensor or did you make something that can work up the tailpipe?
also i read that CO is sometimes used to help tune the carb, has anyone built one of those?
cheers
dinghyguy, asphyxiating in the dungeon
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
rebar1111
Patron 2019
Patron 2019
Your car is a: 1979 124Spider
Re: air fuel ratio meter DIY
Post by rebar1111 »
I just went through that process and here is what I found using an O2 sensor in the exhaust.
2L engine with 1800 head and intake with Weber 34ADF and 421 downpipes. 40-80-40 reground cam. No smog equipment. Manual transmission. Ambient air @ 65deg F. Eng temp @ 185 deg F. Timing @ 10deg BTDC.
Results were A/F between 14.0 and 12.5 from 1000 to 4000RPM
************************Primary *********Secondary
Idle Jet *******************60**************80
Main Jet******************130*************140
Emulsion tube***************F2*************F5
Air correction Jet************45*************180
Syncro Air Flow @ Idle********20**************2
kilrwail
Post by kilrwail »
I didn't build my own, but I do have an Innovate AFR system in the Porsche, with oxygen sensors in both headers, within about 6-8" of the collector joint. It's very useful for choosing the correct jets at initial engine installation. It's also very useful for tuning and balancing all six carburetors with each other and side to side. Just a note of caution - when you select your main jets, make sure they're sized to give an AFR reading of 90% Lambda (13.23 = 0.9 x 14.7) at maximum revs. Anything leaner than that would be dangerously hot. FYI in an air-cooled engine, that threshold is 85% Lambda.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Nut124
Post by Nut124 »
I have had a fuel/air ration readout on my dash for 20 years. It came from one of the US Fiat parts experts, not sure which.
It uses a standard O2 sensor. I had a nipple welded in the ex manifolf for the sensor.
It works well and is a must if jetting carbs.
Nanonevol
Your car is a: 1977 Fiat 124 Spider
Post by Nanonevol »
rebar1111 wrote:I just went through that process and here is what I found using an O2 sensor in the exhaust.
A 45 Primary Air Correction jet? That's not a typo?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
bluespider262
Your car is a: 1979 Spider
Post by bluespider262 »
I have an innovate wideband on my spider. I welded a bung into the pipe right at the back of the wheelwell sticking straight up. Works great and easy to get to when I want to move it to one of my other vehicles.
rebar1111
Patron 2019
Patron 2019
Post by rebar1111 »
Sorry that 45 should have been a 145. Thanks for pointing that out.
dinghyguy
Post by dinghyguy »
Thanks to all of you
So I am sensing. Weld bung in. Use Bosch 02 sensor pick gauge and interface adapter and go for it.
Dinghyguy
wetminkey
Post by wetminkey »
Gosh, and all of these years I've been tuning carbs by ear,...
Hee, hee!
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
zachmac
Post by zachmac »
I've always used a colortune. http://colortune.net/
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
rebar1111
Patron 2019
Patron 2019
Post by rebar1111 »
Gosh, wetminkey, maybe now even you can get it right.
wetminkey
Post by wetminkey »
Didn't say I wasn't getting it right,...
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
dinghyguy
Post by dinghyguy »
ok so now i have learned something......not that wetminkey has a bad ear, but about colortune. Never knew suck a thing existed but it makes sense to me. so has anyone compared the colortune to the AFR meter results? If so what did they learn?
educated a bit , in the dungeon
dinghyguy
wetminkey
Post by wetminkey »
I recall a very primitive version of Colortune back in the 70's, I believe,...
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
wetminkey
Post by wetminkey »
Not quite 50 years ago, I was taught by a high school buddy how to tune a 4bbl by ear. I've been tuning single, 2bbl, and 4bbl carbs by ear for all that time. I can get power/emissions pretty accurate on my cars, trucks, and tractors,...
I can do single carb setups, but multi-carb setups cannot be approximated by ear.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
