Lower console Trim Bezel removal
Zoofly
Post by Zoofly »
Can someone explain how to remove the silver trim bezel on the lower console? Is it just a matter of pulling it straight out?
2020 124 Spider Abarth
2019 Alpha Romeo Stelvio - sold
1977 Triumph Spitfire
2017 Fiat 124 Spider Classica - sold
1999 Jaguar XK8 - sold
1998 BMW Z3 - sold
1988 Pontiac Fiero - sold
mighty7
Your car is a: 1985 Pininfarina Spider Azzura
Re: Lower console Trim Bezel removal
Post by mighty7 »
post a pic so we know what your referring to
Zoofly
Post by Zoofly »
It's the silver radio speaker cover.
Her'e a link to a pic of one.
http://www.midwest-bayless.com/images/p ... 688_3_.jpg
1998 BMW Z3 - sold
DRUMMOND
Post by DRUMMOND »
The trim has four tabs on it. you need to bend them straight from the rear of the fascia, then it pulls out
Zoofly
Post by Zoofly »
So I'd need to pull the upper center console out in order to do that correct? Is it possible to access the tabs if I remove the car stereo?
1998 BMW Z3 - sold
johndemar
Post by johndemar »
May be easier to remove the center console, unless you are really flexible.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
DRUMMOND
Post by DRUMMOND »
You will have to remove the center console, two tabs on the top, two on the bottom. you may get the ones on the top from removing the radio, but I doubt you can get the bottom ones.
