Plastic headlamp Ring Conversion
- Your car is a: 1981 Spider
Is there some mystery source for these rings, the thick black molded rings that fit just behind the chrome rings? somewhere that does not sell them for $33 each? Or alternative? 3-D printing? Anything? I won't ask if the Italian engineers were inebriated when they designed the headlamps to attache with these.
Re: Plastic headlamp rings
My Spider, through some terrible misfortune, ended up with one of each,...a pre-'79, and a post-'79 headlight bezel attachment. I tried to replace the black plastic ring, but my old one is flat and round, while the new one has an smooth extension to one side and a lot more trim plastic (bezel to fender) than just a "giant washer", like my old one.
I'm done with the plastic ring.
I've devised a way to add headlight bezel mounting tabs to my fender's headlight 'can' (that mounts the headlight bucket). That will give it a headlight bezel attachment just like the pre-'79 fenders. My driver's side headlight 'can' has a small 9/16" cutout at the top of the 'can', and a similar 3/4" cutout at the bottom. Identical to the older fenders, just missing the tab to hook the top of the bezel, and the tab w/hole, for the bezel's attachment screw at the bottom. I also find a thin space, between the 'can' edge, and the fender, in each location. These spots are not welded closed, and strips of metal will fit through these slots. After bending 90 degrees (to conform with the back of the headlight 'can', inside the wheel well), they could be MIGed to the back edge of the 'can'.
I do not know if your headlight 'cans' have the same small cutouts and slots. If so, this MOD could easily be accomplished on your car!
Just devised this today. Haven't completed it, but I have light cardboard templates already,...
Hope this helps.
Engineering most of the time,...Todd.
Hope this helps.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
I see this to be possible with both, different types of fenders. Each has a slot at the top that will accommodate a tab,...both the old fender that uses a rubber strip as a gasket, and the newer fender that uses a black, plastic ring.
The older fender still has it's lower tab, and the newer fender has a slot at the bottom to accept a tab. I'll be able to make BOTH fenders accept the headlight bezels in the same manner!
Brady is going to cut proper sized strips of sheetmetal for me,...they'll wrap around the outside of the back of the 'can' that houses the headlight bucket, inside the fenderwell. They could be just left as is, JB Welded, or MIGed in place. Then undercoated,...
More ASAP. Todd.
More ASAP. Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Keep posting Todd! I'm done with plastic rings, too. Sounds like you are on to something good.
I'm really curious to know, to see, how the chrome ring sings on the headlamp hole w/o a ring.
Curiosity is killing me, rodo,...are the post 1979 fenders all configured the same way, or will this only work on my particular fender?
If you have a headlight bezel off, can you spot a slot at the top, and the bottom, of the fender to headlight 'can' that the headlight bucket mounts into? If so, THEN I might be on to something!
I bent down the remains of the shorty tab on my pre-'79 'half a fender' and I find the very same slot, between it and the welded headlight 'can'. So, I'll replace my stubby tab for a new one of proper length. Got some pics that I'll post after downloading,...
Todd.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
- dinghyguy
- Your car is a: 1981 spider
I just took the headlight ring off my 1979 to get the headlight adjusted so it would pass a safety inspection.....and i am confused about the plastic ring you guys are talking about, please post a picture. Oh and would the 78's have it too, because being such an early 79 some things are still 78 on my car.
cheers
dinghyguy
cheers
dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
Guess I'll need some more pics,...coming soon!
Here's the 1979/pre-1979 fender with the headlight 'can':
You can see the small slot at the top of the headlight 'can' edge, that contains the welded metal hook (bent end of a 9/16" metal strip) that retains the top of the chrome headlight bezel/rubber seal. The hook in this photo is a bit shorter than it needs to be. At he bottom, you can see that this headlight 'can' still has a usable 3/4" metal strip for the headlight bezel retaining screw.
This is my driver's fender, with the black plastic headlight bezel retaining ring removed:
This fender/headlight 'can' also has the same slots, top and bottom.
I can see that I need some pics of headlight bezels in place with the thin rubber strips. I'll get one of my plastic retaining ring in place on my newer fender,...
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
This is the black, plastic headlight retaining ring, dingyguy. It snaps into the headlight 'can', and the chrome headlight bezel snaps onto it:
And here's my older fender, with the bezel/thin rubber seal in place:
This is the newer fender, with only the bezel/thin rubber seal in place. This is what I propose to accomplish with a couple of thin strips of sheet metal:
Bingo, no plastic rings.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Plastic rings were only used from 79 on, not used before that so you always have the option of retrofitting the pre-79 assembly but that has to cost more than the plastic rings (Midwest Bayless has them I think for under $20).
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
So, I have still not seen the answer to my question,...
Do ALL Spider fenders have slots, top and bottom?
Whaddya think dinghyguy,...have you looked?
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
And I'm doing this for FREE on my Spider. Just some scrap metal. Began the change-over yesterday.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
- dinghyguy
Ok, so went and put the beauty rings back on the lights on my early 79 (in the first 100 of the series) and thus likely a 78 in this detail. The pix are below.
Hook the chrome ring over the tab at top, fix it with a single screw into the tab at bottom.
No plastic ring like you guys are talking about, but a rubber bit around the chrome ring, presumably to protect the car paint.
Hope this confuses people further.
cheers
Dinghyguy
cheers
Dinghyguy
Thank you, sir! I appreciate the pics!
This is identical to my passenger side fender (before, and after, the most recent accident). So the damaged fender, and the 'half a fender' share the "hook and tab" bezel attachment. I would guess that if dinghyguy were to bend that tab down, he would find the 9/16" wide slot that I'm going to use to repair my short tab. My bottom tab, for the bezel's screw attachment, can be used without problems.
HOWEVER, on my driver's side, as you can see from the pics, I have a black plastic ring that attaches to the fender first, and then the chrome headlight bezel snaps into it (held at the bottom with a screw - into the plastic). There are no tabs. Looks crappy, works crappy, and mine needs replacement. And it's not the same shape as a new one.
So,...get rid of the black plastic ring!
That's what I'm doing. I should have the sheet metal strips this week,...
Fiat changed the design starting in 1979, but it seems earlier fenders were being used up at the same time,...and who knows what was installed if one was replaced/repaired later on.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
- dinghyguy
Glad to be of service
Now all you need to do is get proper chrome bezel to go with your beauty rings!
Cheers
dinghyguy
Cheers
dinghyguy
I'm cool there,...all of the bezels are the same. The only changes Fiat made were to eliminate the attachment tabs and that thin rubber bezel seal. They used the black, plastic ring as the new mechanism to attach the bezel and the plastic replaces the rubber seal. All of this happening in, and around, 1979.
I've seen a couple of Spiders with two different types of bezel mountings (pass. vs driver's side), like mine. Mix 'n' Match!
As an aside,...I also notice some slight changes in the older fender's contour, just at the headlight area. The older fender (passenger's side) has sharper angles around the 'teardrop' shape of the headlight area. It also has a tighter contour around the headlight area. The newer fender has more rounded angles, protrudes a bit more at the fender crease near the side reflector, and over the headlight 'brow'. I'm making some minor changes to match the two.
I figured that all of you Spider veterans already knew all of this,...sorry to cause such confusion!
Todd.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
