Gearbox woes
gjonsey
Your car is a: 1976 124 Spider
Gearbox woes
Post by gjonsey »
So I guess transmission is kinda in engine and tuning?? Either way ,I need help dismantling my gearbox. The mainshaft is supposed to removed by "flattening the tab on the mainshaft nut locking washer so that the nut may be undone and the spider pulled off the mainshaft".
Anyone understand that??
What tab is being bent?
wetminkey
Re: Gearbox woes
Post by wetminkey »
Mainshaft nut's locking washer. The tab is on it. You will find it bent over the edge of the nut, locking it into place so that it can't rotate.
Best of luck with your project! Never been into Italian transmissions,...mine is an automatic.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
gjonsey
Re: Gearbox woes
Post by gjonsey »
wetminkey wrote:Mainshaft nut's locking washer. The tab is on it. You will find it bent over the edge of the nut, locking it into place so that it can't rotate.
Todd.
Hmmm... Well I see the piece of metal and bend it back, but I can't get the nut off. Is there any special way to do it?
Btw, are there perks to being a patron?
Nanonevol
Your car is a: 1977 Fiat 124 Spider
Re: Gearbox woes
Post by Nanonevol »
Hmmm... Well I see the piece of metal and bend it back, but I can't get the nut off. Is there any special way to do it? [/quote]
Torque. Serious torque
Btw, are there perks to being a patron?[/quote]
Yep, become one and find out!
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
gjonsey
Re: Gearbox woes
Post by gjonsey »
How much torque? I had someone hold the other shaft down with a screw driver, how else can I get it to sit still?
What is the cost of patron?
gjonsey
Re: Gearbox woes
Post by gjonsey »
gjonsey
Re: Gearbox woes
Post by gjonsey »
Nanonevol wrote:Hmmm... Well I see the piece of metal and bend it back, but I can't get the nut off. Is there any special way to do it?
Yep, become one and find out![/quote]
Nanonevol
Re: Gearbox woes
Post by Nanonevol »
If you have or can borrow an impact wrench, that might help.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
courtenay
Re: Gearbox woes
Post by courtenay »
What is the cost of patron?[/quote]
Make a donation to the Forum and you will become a Patron.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
gjones1967
Your car is a: 1979 Spider
Re: Gearbox woes
Post by gjones1967 »
Air tools! Recently invested in a 21 gallon compressor and tools, made life so much easier and spent less than 400 bucks!
Graeme Jones.
1978 Fiat Spider
1979 Fiat Spider
1986 Porsche 944
1976 MGB
2009 Honda Accord
2016 Toyota Tundra.
