Oil pump drive gear problem
- mm1000
After rebuilding my 1800 engine with new rings etc and also a new oil pump, the drive gear doesn't appear to go in deep enough to turn the oil pump and the distributor won't go in all the way. Have I made a mistake or do you think the oil pump is wrong - which is my suspicion?
- Yadkin
- Your car is a: 1974 Spider
Re: Oil pump drive gear problem
Do you have the old pump to compare it to?
- mm1000
Unfortunately not as I got someone else to do the block work, including a new oil pump. This was a few months ago now. I'll have to take it all off and do some measurements. I think the pump might be for a 1600 Spider so I wondered what the difference was?
