1980 spider Restoration phase 2
rodo
Your car is a: 1981 Spider
Re: 1980 spider Restoration phase 2
Post by rodo »
Wow, right there with the other comments: amazing job, such detail! nice.
Wonder if you could talk a bit about how you handled the dash. I've got mine stripped (of vinyl) and I'm just not sure which direction I want to go. Did you also stitch it together? Glue it in? Thanks for any advice.
DRUMMOND
Post by DRUMMOND »
Hi Rodo
My dash was pretty beat up. top was badly cracked and the paper mash on the inside had white mold growing on it. That was my starting point. I dried it all out, opened up the cracks To make sure the body filler would have a good depth to solidify and have decent adhesion. Sanded it all level. Sealed the whole dash with fiberglass resin, two coats inside, this adds strength for the glove box and instrument binnacle.
I then made a pattern for the Vinyl and sewed it up this way. It is stapled onto the dash underneath so no glue. This is just my preference, if in the future I need repairs, it will come off fairly easy. Here are some photos
White mold
So far so good!
Let me know if you need more info
DRUMMOND
Post by DRUMMOND »
Update So far:
All electrical systems Finished and Working.
Total renovation of wiring loom, All terminals/wire labeled, Upgraded all lighting systems to LED, Added DRL's, Bluetooth amp, Automatic Lights, Added 2 new fuse boxes & Original renovated fuse box, Upgraded engine bay grounding stations, Added new ground station to trunk (mainly for Amp, Lights and Fuel Pump) Remote Charge pins for Battery, Automatic doors with poppers, Magnetic switch for trunk light (no longer have to have lights on to work), New driving Lights, All heavy draw equipment on Relays, New light switch, Pushbutton start.
Next up, brake fluid and Bleeding brakes
Fantastic! Really inspiring work.
dinghyguy
Your car is a: 1981 spider
Post by dinghyguy »
Hi Drummond,
As always, wow. I have to ask what the additions under the dash are for, it is not readily evident in the latest photos. Also, are there 4 lights behind the grill (one hidden by the cloth ) or only 3? Whose lights did you install?
And finally, when is the test drive? I hope there will be some video!
cheers
dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
DRUMMOND
Post by DRUMMOND »
thanks for the nice comments!
Dinghyguy
driving lights are: Pilot Performance Lighting PL-195C Pilot 4"
Main Lights are: Allisson automotive Fiat Spider H4 Headlamps with Two LED Circuits
Signal Lights are:GPPOWER Universal super thin 6-LED Amber
only two lights behind the grill. the left side holds the air filter, the right side is a Polished SS block off plate which holds the horn compressor and 4 relays
Additions under the dash: they are the old air conditioner vents, Just replaced the vents with aluminum plates as they were all broken. also helps hide all the wiring.
AriK
Post by AriK »
Yes +1! Truly inspiring progress. Keep up the great work!
familyman
Your car is a: 80 Spider
Post by familyman »
Something I change when restoring Spiders is to move the wiring that is normally strapped to the top of the left foot well on the driver's side. I don't like that the carpet doesn't conform over this lump of wires. On one of my cars, I opened up the loom and got enough slack free to route the bundle of wires along the bottom of the foot well so it was less visible. On my current project, I plan to open up the bundle of wires, and get them to lay side-by-side so that they conform to the shape of the sheet metal. I may just glue them in place. Then the carpet will hide the wiring and lay tight over the shape of the sheet metal. Likewise, I have built up the lower portion of the floorboard on the passenger side (where the catalytic converter bumps up the floor board), so that the passenger floor board is flat, like on a pre-catalyic-converter Spider. It's amazing how these two changes improves the overall fit and finish of the carpets.
DRUMMOND
Post by DRUMMOND »
Landmark Day! All four wheels on the ground for the first time in 2 years. Not all pointing in the same direction :D Setting up suspension and alignment.
nelsonj
Your car is a: 1972 Spider 124
Post by nelsonj »
The paint looks gorgeous - can't wait to see it with doors and seats! Please keep positing, and congratulations on reaching this mile stone.
Simi Valley, California
Spider 1800
Romans 10:9
DRUMMOND
Post by DRUMMOND »
All alignment done!! :D
Some weird measurements though but base line is at least done. Never had to preload a car with weights before setting suspension that's a new one or old?
Now onto door internals. Install of electric puller, Greases and rehab of all pulleys. cables and motor/ plus speaker frame
Emergency trunk release install
Belly pan Fabrication Stainless Steel
Next up Tag holder & Oil Pan Protector
DRUMMOND
Post by DRUMMOND »
Now onto door internals. Install of electric puller, Greasing and rehab of all pulleys. cables and motor/ plus speaker frame
ORFORD2004
Post by ORFORD2004 »
Look like I won't be the only one with door lock :lol:
DRUMMOND
Post by DRUMMOND »
Orford2004 Yes now there is two :D
Completed door card Trim
Gplayer
Your car is a: 1980 Spider
Post by Gplayer »
So quick question, going a bit far back in your thread, how much sound absorbtion mat did you need to do the whole floor pan?
