Stock air filter housing 1979
wetminkey
Post by wetminkey »
There is a flap that diverts the intake from warm air (from near the exhaust manifold), to cool air, coming through the larger intake 'snorkel'. I don't think that the flap's thermostat is working. Is there a way to test it? And if I need to, where can a replacement be found?
I find no info on the forum, and no sources on the internet,...
Thanks, all!
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
geospider
Re: Stock air filter housing 1979
Post by geospider »
Hey Todd,
I'll check mine out. on the shelf since I have the lunchbox filter on the weber.
been busy with upholstery; the stuff from Convertible Top Guys is great.
Geo
scusi
Your car is a: 1979 Fiat 2000
Post by scusi »
What did you buy from them to redo your upholstery?
wetminkey
Post by wetminkey »
Thanks, and I'll see if I can tear into mine a bit to determine if it's truly non-functional.
Have a good weekend!
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
geospider
Post by geospider »
Scusi
http://www.convertibletopguys.com/conve ... t-Spiders-
got herein about 2 weeks; looks great so far... great fit, Of course I am doing my best at first time doing this. the tan color is perfect: chamois.
pics coming
dinghyguy
Your car is a: 1981 spider
Post by dinghyguy »
Hmm m
So I took my air cleaner off the shelf and using the hair dryer I blew hot air in from the side that connects above the exhaust manifold. Things got hot to the touch but no movement of butterfly.....
But I do seem to recall there is a summer winter setting on the cleaner described in the owners manual
So sorry, no help but the wife was amused by the hair dryer episode.....
Dinghyguy with the perm
In the dungeon
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
Odoyle
Your car is a: 1983 Pinafarina Spider
Post by Odoyle »
From what I recall, my 79 had separate piece which attached to the filter housing and sucked hot air above the exhaust manifold.
wetminkey
Post by wetminkey »
That's correct, Odoyle. I'm trying to figure out how to get it to QUIT sucking warmed air once the engine is at temp.
Dan, you're a nut! Geeze,...guess I am too!
Thank you for trying!
Anyway, I've cleaned, lubed, and repeatedly moved the mechanism enough that if it doesn't work now, it's certainly dead. I'll check the Owner's Manual,...Shop Manual has nothing. Although, a strange diagram that I ran across refers to Wide Open Throttle (WOT) and idle pathways,...I thought emissions, or vacuum. I'll check. Perhaps the damn thing only opens with warmth AND carb vacuum,...
I'll post if I find out.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
wetminkey
Post by wetminkey »
It's called the air cleaner throttle valve. Owner's manual pg 30. And it operates freely and spring returns it.
I'll watch for operation while running and report back if I learn anything.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
spidernut
Post by spidernut »
I ran a long screw from the bottom of the air snorkel to hold it permanently open. These cars warm up so fast that the diverter didn't really make that much of a difference.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
wetminkey
Post by wetminkey »
Ha, ha! Believe me, I was planning a similar solution if I'm not satisfied with it's operation!
My big V8s do not require preheat to their 4bbl carbs, and they are HP beasts that need to warm up before driving (and about one full minute does it). My 4x4 FRANKENTRUCK goes in the snow all the time!
This inline 4 should do fine without, and I've seen exhaust manifold covers that do not have the preheater outlet on top. I'll look for one and dump the preheat setup, if I block the intake open.
Thanks spidernut!
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
