I need to remove my drivers door latch for a little welding repair on the end of the door right where the latch comes out of the door.
Anyone have good advice/experience that might make this process simpler? I have looked at a donor door but not sure the best way to do this from inside the door. Eventually I will be painting so I might as well get the practice of taking off the components.
Thanks for the help.
door latch removal
- Your car is a: 1982 Fiat Spider
- Odoyle
Re: door latch removal
Just recently did this one on my 77. First have door cards off, glass for windows comes out next. Not hard, just use window crank to get window to position where you can remove the two Phillips head bolts with a 10mm nut on back holding the window to cable wire. Then remove the felt window guide piece (remove 10mm nut behind the circular rubber gasket on the far side of the bottom of door) Then you can remove part #5 in diagram. As for the door handle assembly, 77 is different so can't speak on that part.
