Losing coolant
Martyn
Your car is a: 1985 Pininfarina Spider Europa
Losing coolant
Post by Martyn »
Went on 100km drive today. Coolant temp gauge initially just below 90 once warm, but dropped to 50 by end of trip. I probably lost up to 2 pints of coolant.
Will look for signs of leaks in week, but any ideas of cause of combination of low temp and low coolant?
Thanks in advance.
GeorgeT
Re: Losing coolant
Post by GeorgeT »
Weak spring in the radiator cap may be the cause. Also, check your thermostat to see if it is stuck open.
bobplyler
Re: Losing coolant
Post by bobplyler »
Also, when the coolant is low, it doesn't reach the temperature sending unit, so it won't report the correct temp.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
fiatfactory
Your car is a: 1970 128
Re: Losing coolant
Post by fiatfactory »
Martyn
Re: Losing coolant
Post by Martyn »
This makes sense. I have discovered a bead of coolant on water pump, but no staining on garage floor, which is odd, but maybe loss greatest when driving and coolant is under pressure.
No sign of gasket damage (yet?). Oil looks OK, no exhaust water. Will get pressure tests done and then consider next steps I think.
Thanks for all the help in diagnosing issue.
Martyn
Re: Losing coolant
Post by Martyn »
This afternoon I discovered additional symptoms. The car heater doesn't work. The lever control only goes halfway but no heat at all.
After topping up coolant (about 1 litre) and bleeding the system the temperature gauge rose to ~ 60c after running the engine for 15 minutes. But the pipes to the heater were cool. Could an air blockage in this part of the system be a cause?
