Engine type
Laserman
Your car is a: 1976 Spider
Engine type
Post by Laserman »
Hi folks.
Just entered the board due to my upcommi g purchase of a nicely restored 1976 Spider.
However the engine is not the original but is a 132 CS2 000 I beleive.
Could any body give me the performance specs. on this engine?
Thanks in adv.
Lars
hayesbd
Your car is a: 1973 Spider
Re: Engine type
Post by hayesbd »
Hi and welcome! If your engine is a 1592cc 132 type, it may be similar to my 1973 version which supposedly makes 87 HP at 6200 rpm. Peak torque is 85 ft-lbs at 4200 rpm.
Mine's a very tame car, but nonetheless is a delightful experience.
Hope this helps and best regards,
Brian
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
Laserman
Re: Engine type
Post by Laserman »
Thans for your reply Brian
I have to make a correction on the serial no.
It is 132 C2 000.
Current owner claims it to be a 1995 ccm.
Rgds.
Lars
aj81spider
Re: Engine type
Post by aj81spider »
132.c2 is a 1995 cc engine. I'm not sure what the 000 variant is, but haven't seen that as a Fiat Spider model (which doesn't mean it isn't). As best I can tell from a Google search is that it is an engine from an Argenta 1981-1983.
Specs for it can be found here:
https://en.wheelsage.org/fiat/132_c2.00 ... fications/
A.J.
2006 Corvette
Laserman
Re: Engine type
Post by Laserman »
Thanks alot AJ. :D
Just what I was looking for.
I think I'll go for it then.
Lars
