Hi, This question is for any serial number experts. I have a '78 1800. However, after looking at the serial number stamped into the engine block, I think I have an engine out of a '73. I think it's a 1592, if I remember correctly. Does that sound right? And does anyone know what the horsepower is on that particular motor?
Thanks in advance!
Engine serial number
- Hootch
Hootch McGee
1978 124 Spider (1592 cc motor)
2012 Mini Cooper Clubman S
2004 Aprilia Mojito
2004 Aprilia Mojito
- AndyVAS
Re: Engine serial number
That 132 AC 040 3 does show to be a 1592. Not sure of the exact power figure. I would think with the best of the stock manifolds and carb that it would be roughly 80hp at the flywheel. Maybe 85hp on the high end and 70hp on the low side depending on tune and wear.
Andy Phillips
http://www.vickauto.com
- Hootch
Thanks for the info, Andy!
It has very little power in the lower gears, but there's a little blow-by that I'll need to resolve. I'm hoping that will help a bit.
Hootch McGee
2004 Aprilia Mojito
2004 Aprilia Mojito
- hayesbd
- Your car is a: 1973 Spider
Per the official book, a stock 1592 makes a maximum of 87 HP for a USA version from 1973.
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
