Help - metal grinding noise *SOLVED*
adrians
Your car is a: 1981 Spider Turbo - missing the turbo
Post by adrians »
Hi All,
Need some help identifying the source of a metal grinding noise.
Yesterday I drove to a car show - about 60Km there and another 60Km home in the afternoon.
I had checked and topped up the oil prior to leaving in the morning.
Start to notice a strange noise when I was leaving the show.
When I got home the noise was really prevalent as I drove into the garage.
The noise is only there at 1500 - 2400 rpm - As per the attached video, noise start at 3 second mark.
https://youtu.be/vlitZ6qX6JM
The sound appears to be coming from the front of the inlet cam housing, I pull the cam cover off the the cam looks okay - with heaps of oil present.
Motor is stock 2.0 litre with standard F.I., motor was rebuild in 2009 - low mileage since then. Timing belt is okay.
Any Ideas ????
THE FLEET
2014 Abarth "SS"
TwinFast
Re: Help - metal grinding noise
Post by TwinFast »
It looks like something is touching rotating part. Look at the fan, alternator, cam cover or belts ....
Fiat 124 Spider 1.8L 1978
Jaguar XKR 4.2L 2009
Harley Davidson Fat Bob 96Ci 2011
Odoyle
Your car is a: 1983 Pinafarina Spider
Post by Odoyle »
+1 to TwinFast's comment
Make sure radiator fan/housing is not contacting the water pump.
adrians
Post by adrians »
Thanks for the replies,
I've checked the fan belt, CAM belt, the steel fan blades on the alternator - nothing touching. Electric fan for the radiator, so it wasn't running at the time. Check if the was any wiring touching anything.
Does the inlet cam have a bearing in the seal behind the cam wheel ?
Next I'll be getting the timing/cam belt cover off !
THE FLEET
2014 Abarth "SS"
Odoyle
Post by Odoyle »
No bearings, cams seat inside the cam tower housing. Might have excessive play between cam journal and the housing, which is rare, but possible considering you mentioned everything came apart in 09. Was intake cam replaced then?
bobplyler
Post by bobplyler »
Are the cam pully bolts tight?
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
adrians
Post by adrians »
ODoyle - Cam wasn't replaced - same cam used, the pistons were replaced in '09.
bobplyer - Bolts - I hadn't thought of that - I'll be pulling the cover off next.
THE FLEET
2014 Abarth "SS"
fiat218
Post by fiat218 »
Timing cover rubbing on the pulley
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
adrians
Re: Help - metal grinding noise *SOLVED*
Post by adrians »
Thanks for everyone's input,
Solved the problem today, after I put an inspection camera down each cylinder and did a compression test !!!
I found the fan belt had a bit of lack.
So, it wasn’t the valves, cam shaft, tensioner bearing or any moving part.
It was the lower bolt and nut on the alternator.
The nut had come off and the bolt was moving around, when the engine revved higher the alternator would move and create the grinding noise, - new nut, tighten it all up and no noise now.
All fixed ! ! ! !
THE FLEET
2014 Abarth "SS"
TwinFast
Post by TwinFast »
Nice to hear that good news ... :D
