Overheated, Fan issue, Radiator
ylbill
Post by ylbill »
Car overheated sitting in driveway and now have two issues. Fan didn't come on, checked lower house and it was cold, so I purged system and got that corrected. but fan still doesn't come on automatically when up to temp. Tested fan and it works, just doesn't turn on when temp is up around 190.
Also, since overheated, steam from lower part of radiator, so it seems it did some damage to radiator and probably needs replacing.
Suggestions on why the fan won't come on and resolve of steam from lower radiator.
New radiator and switch??
Sscottdvm
Your car is a: Fiat 124 1971
Re: Overheated, Fan issue, Radiator
Post by Sscottdvm »
Just had the same problem with the fan not coming on. Turns out the wires going to the switch were corroded. It's either the switch or the ground wires. If you short the wires going to the switch and fan works then the switch is bad. If not probably just check the wires.
1978 Fiat Spider 124
BMW M3 2008
Subaru Forester 2008
MGB 1971,
nelsonj
Your car is a: 1972 Spider 124
Post by nelsonj »
Horn and fan share the same fuse. Does your horn work?
If no, check the fuse first.
Simi Valley, California
Spider 1800
Romans 10:9
ylbill
Post by ylbill »
Sscottdvm wrote:Just had the same problem with the fan not coming on. Turns out the wires going to the switch were corroded. It's either the switch or the ground wires. If you short the wires going to the switch and fan works then the switch is bad. If not probably just check the wires.
Yes, I shorted the wires and the fan came on, so guess I need a new switch. Thanks
That's the cheap small job. I guess I'm more concerned with radiator. Steam from lower area of radiator, seems like the overheating did some damage. I'm going check again, because there was coolant over due to purging. I want to be sure the steam wasn't from the coolant overflow. I don't think it was because the steam looked like it was pushing out. More time and $$.
ylbill
Post by ylbill »
nelsonj wrote:Horn and fan share the same fuse. Does your horn work?
I was able to short the wires and the fan does come on, so I did confirm that the fan works. Looks like a new temp switch.
Should I start with just the switch or does it sound like the radiator is bad too? There was some coolant overflow, so I was hoping it was coolant evaporating, but it doesn't seem to be going away.
Like the verse!
DUCeditor
Your car is a: 1977 FIAT 124 Sport Spider
Contact:
Post by DUCeditor »
In all the (almost 30) years I've owned my Spider I never was aware of the fan coming on. Nor has it ever over-heated.
I aways assumed that was because I never drive it in traffic -- just on open, free, two-lane roads.
But still, when I was replacing my water pump, and thus renewing my coolant (after a flush), I replaced the switch at the bottom of the radiator.
The fan still doesn't come on that I am aware of. Or the car overheat.
-don
ylbill
Post by ylbill »
DUCeditor wrote:In all the (almost 30) years I've owned my Spider I never was aware of the fan coming on. Nor has it ever over-heated.
The fan still doesn't come on that I am aware of. Or the car over-heat.
-don
Thanks for your input Don.
I guess if you haven't had a problem, why mess with it.
I know for sure if my fan doesn't come on my car will over-heat.
ylbill
Post by ylbill »
Checked the horn and it worked.
ylbill
Post by ylbill »
Horn worked, fan works when shorted.
ylbill
Post by ylbill »
Yes horn works. I shorted the wires and the fan came on, so guess I need a new switch. Thanks
brackie1
Post by brackie1 »
if lower hose is still cold, it indicates you may have a thermostat problem. They aren't expensive so I would replace it first before assuming you have a bad radiator.
Gene
North Carolina
ylbill
Post by ylbill »
brackie1 wrote:if lower hose is still cold, it indicates you may have a thermostat problem. They aren't expensive so I would replace it first before assuming you have a bad radiator.
Thanks Gene, I did check the lower hose and it does get hot. Last time I ran it everything ran fine. Something within the cooling system chain didn't appreciate it getting too hot and overheated. Would the lower radiator switch stop working because it overheated?
brackie1
Post by brackie1 »
Don't think so. Sounds like a bad fan switch. I know I've put two in my '77 in the last 4 yrs. You might also check the ground notorious for going bad.
Gene
North Carolina
ylbill
Post by ylbill »
Okay, Still having issue with fan not coming on. Just flushed coolant and installed new fan switch. Still no fan when at temp it used to come at prior to the overheat. Fan works, bottom hose hot, new fan switch. What else should I be checking, test replacing? Thanks
Check the ground coming off of the fan switch. Its connection is over in the cluster on the driver's side fender well. The switch input side from the fan is always hot, the switch gives it a path to ground. Thus it can run when the ignition is off.
