Please help identify
blazingspider
Your car is a: 1977 fiat spider
Re: Please help identify
Post by blazingspider »
Mine has the 3-way part, with the 3 hoses in and 1 out, but it is smaller and works as a fume collector (and assumed liquid separator).
Maybe he has a sealed replacement cap when a vented cap was original on his configuration? :?:
Any spider that came with an evap emissions system did not come with a vented gas cap and they also have a 3 to 1 fume collector in the trunk.
The schematic for the carb'd version of the evap emissions system is quite a bit different than the one for the fi cars.
The fi cars have that check valve underneath the car and no 3 way valve in the trunk. The carb'd cars have the 3 way valve in the trunk with no check valve underneath the car.
Make up air in a carb'd car is pulled from a small orifice built into the body of the 3 way valve. Make up air for fi cars is pulled from the charcoal cannister.
Nanonevol
Your car is a: 1977 Fiat 124 Spider
Post by Nanonevol »
Can anyone explain why there would be 3 hoses coming from the tank merging into one hose (see RRoller's diagram and my photo at top of thread)?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
Probably to provide enough volume for the fumes to condense into a drop and flow back down into the tank? It only makes sense if it has something to do with a minimum necessary volume in that section of the line, as there is no anti-tip-over leak valve or anything like that there.
