I expected to see an actual weber 34 adf, but got the car back with a different carb (and a different air cleaner). So, what carb is my car now sporting (see pictures below)?
I'm also having a problem i need help with. The car seems to have lots of power, but i need to feed it gas before taking my foot off the clutch from a dead stop, as well as when changing between 1-2 and 2-3 gears (by the time i get to change between 3-4 gears it seems to work well). if i don't feed in gas the car will lurch dramatically, like it's stalling, but it does recover. So, what is causing this condition and how do i get rid of it?
Also, are the jets correct (see last picture) or could they use tweaking?
