Horrible screech
Nanonevol
Your car is a: 1977 Fiat 124 Spider
Horrible screech
Post by Nanonevol »
I have this horrible screech occasionally when I first start the car. It may continue sporadically for a mile or so but goes away once I'm warmed up. I've done some snooping around underneath but see nothing obvious. Please listen to this and see if it's anything anyone recognizes. It's the noise you hear right after the motor catches.
https://drive.google.com/file/d/0B9_p6T ... sp=sharing
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
kilrwail
Re: Horrible screech
Post by kilrwail »
Sounds like a loose alternator belt. Check the "play" available when the engine is off - should be about 1/4 - 3/8".
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
spiderdan
Your car is a: 1968 124 Sport Spider
Post by spiderdan »
kilrwail wrote:Sounds like a loose alternator belt.
Agree with you Peter.
If play is good I would replace the belt to see if the sound goes away. Some belts over time can develop a "shine" which can cause a slight slip and a squeal. As they warm up they get a better grip.
Dan
"Angelina"
2015 Toyota Camry XSE (hers)
2016 Jeep Wrangler Sahara Unlimited (cottage toy)
http://s1342.photobucket.com/user/68spi ... t%20Spider
http://www.youtube.com/user/Coontache/videos
Nanonevol
Post by Nanonevol »
That would be great if it's that simple. Just had the belt off for a new radiator and water pump. I'll let y'all know when I get a resolution. Thanks
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
I usually need to put the wooden handle of a hammer behind there as a small lever to get the belt tight enough.
Nanonevol
Post by Nanonevol »
As they say at Staples, "That was easy". Thank you all. Sure did sound awful before.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
