fuel line hook up from electric pump to dual carbs
grasshopper
Your car is a: 1976 Fiat Spider
Post by grasshopper »
Hi all. I bought a 76 Spider that I am trying to get going. It has an electronic fuel pump in the trunk. I have installed dual IDF carbs on the car. I am trying to figure out how everything hooks up to the carbs. I noticed a that there is a rubber hose in the trunk that has a plug in it. The other hoses seem to be hooked up from gas tank into pump and back out to engine. What is this little hose with the plug in it for ? And I noticed that when the ignition is on,the fuel pump makes kind of a constant clicking sound. Is this normal ? If anyone has any pictures of their set up both in the trunk and at the carbs it would greatly help me out. Thanks in advance !
vandor
Re: fuel line hook up from electric pump to dual carbs
Post by vandor »
Likely the plugged one is a vent line. Yes, clicking from the pump is normal.
