- coil - within specs
- distributor - looks fine
- AFM - taken apart, track good, door moves freely
- no air leaks - tested by removing, looking for cracks and using propane when engine running
- AAV - cleaned and I see triangle through opening when cold
- ECU - checked resistence values
- cold start injector - works - engine won't start cold with it unplugged
- coolant T temp sensor - resistance looks correct at various temperatures when measured from ECU connector
- all grounds all cleaned and connected fine - including main ground straps
- plugs and connectors good
- fuel pressure good
- fuel clean
- fuel return (or is it called one-way, can't remember) valve working correctly (was plugged up before but I fixed this)
- replaced O-ring on idle adjustment screw
- adjusted idle correctly
Anything else to look into? Or maybe I should be happy that it generally runs fine...
Here's a few videos. Not great but someone may notice something.
Cold start...
https://youtu.be/6eNUsQJyX0c
Running when cold...
https://youtu.be/-FJuNw7mJfI
Running when warmer...
https://youtu.be/Y6vqjvQav3E
I'm leaning towards a minor air leak but couldn't find one.
Richard
