Air filter mounting stud hole stripped
Texafornian
Your car is a: 1977 Fiat 124 Spider
Post by Texafornian »
On my 77 Spider single carb, one of the four holes where the mounting studs screws in is stripped out. Three others are fine. Can I live with it, or is it urgent to fix? If so, what are ideas for how to fix? It doesn't seem like a complete carb replacement is warranted. It is the lower left hole if you are on the driver's side looking down at it. Thanks for your advice!
Daniel
AriK
Re: Air filter mounting stud hole stripped
Post by AriK »
I bought a length of stud and cut it to size. I secured it using 2 nuts on the underneath. I hate that design with those little bits at risk getting sucked into the carb. Be sure to tighten accordingly and use a threadlocker on especially on the top nut.
Ramzi
Post by Ramzi »
I think I may have a couple oversized studs that we were looking at putting into production. Email me directly on Monday and I'll make you a deal
R
Texafornian
Thanks Csaba, I sent you a note!
Daniel
