Correct Fuel Pressure - carb engine
jagonza
Your car is a: 1977 Fiat 124
Post by jagonza »
What is the correct spec for fuel pressure under load for a 77 - 1.8 with a 34 ADF - 10:1 compression , i am installing a new fuel pump and trying to figure out whether i need a fuel pressure regulator, the pump is rated at 4-9 psi.
1977 Fiat 124 - Frankenstein engine
1999 VW Cabrio - Stock
1988 Fiero GT
And a couple of Daily Drivers
carl
Re: Correct Fuel Pressure - carb engine
Post by carl »
I think for Webers it's 2.5-4 psi so you might want to put a fuel pressure regulator on.
klweimer
Post by klweimer »
When I had a carbed Spider once upon a time, I had an electric fuel pump in the back and the pressure regulator up by the carb to keep the fuel pressure up as it travels under the car to get there. The higher pressure should make the car less prone to vapor lock during the summer.
Kirk
jagonza
Post by jagonza »
Carl, thank you
1988 Fiero GT
