Thanks for the quick responses... After doing some more searching, I have decided to post up a few pictures (some mine, some from the web) to verify my scope of work. I am on the road this week, away from the car.. so I thought I do a research.
Step 1.
Remove value for air injection (assume this is a check valve?). Right now the hose connecting to the non-existant air pump is loose. (the original post of this thread)
_____________________
Step 2.
The hose from above connects to this manifold correct? (via second check valve?)
Step 2.2
Plug the 4 holes up (from the manifold above) with this kit?
https://www.autoricambi.us/product/CH0- ... -Plug-Set/
Step 3.
Remove (or plug) xxhaust gas re-circlulation from manifold? I plan on replacing the manifold with a 4-2-1 header.
Should I leave this here for now instead of plugging? I haven't removed the shield yet, so im not too sure how it connects.
Step 3.1
Where does this line run? Is this is, and if so, do I need to plug?
Is this it?
Step 4.
Remove charcoal cleaner (mine looks cracked and busted).
Step 4.1
Disconnect hose from charcoal? Do I plug this connection?
What do I do with the second connection from the charcoal can (bottom hose)? Is this the second hose? (right hose with blue tape going under carb?)
Step 5
Remove fast idle switches? Just curious, what are these for? Hoses and electrical?
Step 6 Remove EGR valve.. I found this on the forums.. is this connected to any components above? Im not too sure where this is at?
