I am finally getting around to installing an EMPI DFEV that I got from Csaba last year. It was appropriately jetted for the engine and intake. It is now mated to a single plane intake, with all ports blocked.
I am carb illiterate and will do my best to explain my issue before I tow the car to a shop. Hopefully it is something simple that I have overlooked.
Background:
Car is a 1973 Spider, 1592 engine. With the original carb and intake it ran fine, but slow. Decided to upgrade.
Prior to my ownership, the car sat for an extended period of time, so the gas tank is suspect. But, seemed to run fine on the old carb.
Issue:
Car will start and idle fine. However, as soon as any gas is given, it will stumble and backfire. Other research says this means lean??
If I very slowly press the gas, I can get it as high as 3500rpms before it will start backfiring. Under quick throttle, backfire is immediate. Cannot be driven as any distance as any amount of load causes backfire and no power.
Done so far:
The fuel pressure seems ok for a mechanical pump, measured 4-5psi at the carb. New lines and fuel filter.
I set the carb initially per instructions (I think). But I found no amount of moving what I believe to be the mixture screw in or out had any effect. I believe what I was adjusting was the proper screw, the one with the spring on it.
I am attaching some photos in the hopes that someone has an idea of where to go next, or sees something obviously installed incorrectly or not addressed. There are a few ports in the carb which are currently not connected to anything, but I believe I read elsewhere that they were unnecessary. The vacuum line from the manifold to the brake booster is installed.
Thank you in advance for any advice and help!
