Rebuilt transmission noisy 3rd
fiatfactory
Your car is a: 1970 128
Re: Rebuilt transmission noisy 3rd
Post by fiatfactory »
grrrdot
Your car is a: 1967 124
Post by grrrdot »
For that last picture with the different style syncro yes. Thats the innards of the old 4psd I pulled out it whined in almost every gear I don't plan on re-using it.
Going out of town tomorrow so I wont get to pull the trans out until after I return. This means I will spend my vacation trying to research whats wrong.
I did find this picture which makes it look like the front layshaft bearing is up against the layshaft, so that might be normal.
-G
grrrdot
Post by grrrdot »
Alright I pulled the trans and got a closer look.
The slider engagement to 3rd gear feels wrong. I can shift into 3rd but as I turn the input shaft there are two clunks and the slider sort of moves for the second clunk. 2nd/1st gear do not behave this way.
https://youtu.be/JCviTN0z1SM
https://youtu.be/Nwk9LMw7UsA
So is something wrong with the hub or slider?
-G
Nanonevol
Your car is a: 1977 Fiat 124 Spider
Post by Nanonevol »
Curious if this got resolved.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
grrrdot
Post by grrrdot »
Nanonevol wrote:Curious if this got resolved.
Nope!
From reading more about different transmission sounds I am going to guess that the layshaft should have been replaced along with the rest of the gears.
I ended up getting a used Lada trans that has the shifter in the correct location for my Sedan so this trans is on the shelf for now. I did notice that the Lada trans makes a similar truck-ish sound on decel when the engine is at low RPM...
-G
djape1977
Post by djape1977 »
glad to see you're alive
check your email
gm404
Your car is a: 1986 Lada 2107
Post by gm404 »
Nope!
-G
Was that noise not coming from the differential, or the loosened driveshaft flange screws on the diff?
The video with the ticking of the engaged gear makes me still think. I build such gearboxes and diffs for my living :)
Was the syncro ring set properly around the gear? It makes about 1,5 turns around it, one end is held by that thin toothed plate
https://nivamart.ru/imgs/21010-1701169- ... 00-0_1.jpg
and "hooked" sideways into a groove, other is pressing the brass ring AND sitting in an other groove. The closing clip has to sit properly in its thin seat. When you press the syncro ring onto the gear by hand, they touch completely and the syncro ring must disappear. I would think the ends of the big syncro ring are put one step (groove) too close to each other, making the ring sit loose and jam behind the edge of the syncro ring. If that is the case, that can be fixed without dismantling everything again.
http://bit.ly/2CQPOGr
redauto
Your car is a: 1980 fiat spider auto
Post by redauto »
grrrdot wrote:If none of the Lada gears are compatible have I ruined the layshaft?
Looks like the 4 speed has a different style syncro so cant use those gears:
-G
all the lada trans parts are compatible except 5th gear. the 3rd gear was new?
1985 fiat spider auto
driven fiats since 1972
www.spiderroadster.com
