http://m.ebay.com/itm/ORIGINAL-WEBER-RE ... ING_ACTIVE
Wanting to upgrade carb and intake manifold on my 1979...this should do the trick, huh?
32 ADFA off eBay...
- Your car is a: 1979 Spider 124
Re: 32 ADFA off eBay...
This would give you more bang for the buck: EMPI 32/36 DFEV Carburetor at Allison's Automotive $255.
Would I still need to get the 1800 single plane manifold?
- Odoyle
I believe you can use the stock manifold with the 32/36, that is what my 79 has, but if you don't need to comply to emissions, get the single plane.
Yes, get a single plane intake manifold.
Emissions is not an issue. Looks like this should do the trick. Thanks!
Can I use stock air cleaner with 32/36? Really want to get rid of the oval cleaner I have on there now. Also have a rectangle cleaner..."lunchbox" style, I guess? Would prefer to go back to stock it possible.
The top of the 32/36 is different from stock. The stock air cleaner can be made to work, but it takes a lot of modification. Better to use the lunchbox.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
But the 32 ADFA & the 34 ADFA will use the stock air cleaner. No mods necessary.bobplyler wrote:The top of the 32/36 is different from stock. The stock air cleaner can be made to work, but it takes a lot of modification. Better to use the lunchbox.
My car had a lunch box when I got it. I upgraded to the 34 and put an original air filter back on. I like it that way. For me the lunch box allowed to much air sucking noise.
The 34 ADFA's are getting hard to find but they are sweet.
- chrisg
- Your car is a: 1971 FIAT
but good induction noise is so nicely Italian...
Chris Granju
Knoxville, TN
'71 FIAT 124BS (pretty), '72 FIAT 124BC,'76 FIAT 128 Wagon(ratbeast), '85 Bertone X 1/9, '70 124BC (project), 79 X1/9 (hot rod in rehab), '73 124BS (2L, mean), '74 124 Special TC, '73 124CS, '73 124 Familiare
Knoxville, TN
