pope wrote:When people say that their going to paint the car, I laugh, because it means different things to different people.
1. To some, a paint job is sanding the old paint and filling in little dings and then laying a new coat of paint over that. That will give you a nice finish for a couple of years.
2. Next upgrade would be to do a clearcoat/basecoat paint job with a sealer coat between the old surface and new paint. WIll last a few years more.
3. Last would be a total paint and body filler removal. Prep the bare metal and spray with epoxy primer, and apply body filler in spots where needed, sand and apply another coat of epoxy primer. Now spray several coats of sandable polyester primer so that you can sand the entire surface to a perfect finish. And tons and tons of sanding. Sealer coat over that and basecoat/clearcoat or even a pearl or candy. After all painted and cured, you begin sanding and polishing the clearcoat finish. Then comes glazing the finish.
It all depends on how long you want the finish to last, and how much you want rust to not show up again.
How did you fill in the badge holes on the trunk and engine lid? What did you use? Did you pick out a color yet? Are you going Silver and Black?
I couldn't agree more, paint is what you put into it, and everyone has different ideas. That being said I have set goals which fit my skill, budget, and intentions for the car. I am not doing a complete bare metal paintjob. In sanding the car to prep for a base/clear I found some imperfections which I have filled(rather I am in the process of filling. I have not needed to remove any metal due to the fact that the tiny bubble I did have was able to be ground out. The only other rust was on the passengers side rocker, which is being replaced. The car was lucky enough to have a previous owner who kept the car out of the rain completely for the past 10 years, which means my job is much easier in the way of rust. It is almost unbelievable the condition of the panels. I have spent the bulk of my time filling little dings, and making sure everything is feathered well. For the badges I welded the holes and filled remainder.
I have removed everything but the front fendres. All trim is removed, all lights removed although side markers are staying as stateside look. Doors, rockers, hood, and trunk will be painted off the car.
The paint will be red body with flat black hood/trunk/cowl(is that what thats called?). The car will likely be used for drivers schools, and Sunday drives... It will basically be very similar to the CSA. This car will last as long as I want it to last, if 5 more spots creep up, I am still in much better shape than most of the rides out there, and with my schedule and interests a full bare metal job is just not realistic.
So any predictions at how much red I will need to cover that black
![Smile :)](./images/smilies/icon_smile.gif)
Actually its sanded down to what looks like a stock primer... anyone know the stock primer color?
Josh
