My 1967 Fiat 124 Spider Restoration Journey
pwilliam
Your car is a: 1972 124 Sport Spider
Re: My 1967 Fiat 124 Spider Restoration Journey
Post by pwilliam »
is that the original dash or a reproduction? The wood consoles look great, by the way!
Mick124
Your car is a: 1967 Fiat 124 Spider
Post by Mick124 »
Dash board was purchased from Autoricambi (Soft Dashboard). I had to send it away to get professionally recovered as the quality and finish of the soft dashboards was ordinary in my case (casting marks, scratches, etc).
If I had to do it again, I would source an original and have it recovered instead of buying reproduction. - Just my opinion though... :D
pwilliam
Post by pwilliam »
Thanks for the info! I've seen the casting marks too so it got me wondering
Sambo42
Your car is a: 1971 Fiat Spider
Post by Sambo42 »
Mick124 wrote:Tank in
Rubber bump stops in.. These were painful to get in...
All new suspension being fitted
Mick it's looking beautiful. I had to ask though - after all the trouble I'm having compressing the front springs with the engine out - how did you get them back in? Did you use a particular compressor? Feeling very much in awe.
Sambo
Mick124
Post by Mick124 »
We tried everything. We ended up compressing them on the bench using a conventional spring compressor, then used wire (medium gauge) wrapped around (a few times) the springs to hold them compressed.
There has to be another way as I thought this was too dangerous. In the end, it worked. Glad that it is finally done
I am sure someone else would know a better more safer way. You may be able to use ratchet straps instead of wire??
djape1977
Post by djape1977 »
there is a special tool for compressing front springs on 124. i have it in stock.
90$ + shipping
Sambo42
Post by Sambo42 »
Mick124 wrote:We tried everything. We ended up compressing them on the bench using a conventional spring compressor, then used wire (medium gauge) wrapped around (a few times) the springs to hold them compressed.
I'm kind of relieved to find I'm not missing something. I bought a special Mercedes spring compressor thinking that would make things easier but no joy with that either so I'm about to resort to the same trick using tiedown straps.
Mick124
Post by Mick124 »
Be careful and good luck
Sambo42
Post by Sambo42 »
Cheers - the rope trick seemed to work...
Mick124
Post by Mick124 »
Engine and running gear all in - minus cosmetic parts and tweaking.
Now she is back at the panel shop to get ready for final paint.
Mick124
Post by Mick124 »
Christmas has come early.
Stainless and chrome all refinished.
Gauges were check and restored. After so many years, I did not want to install and then have Gauges not work properly.
Mick124
Post by Mick124 »
Completed the veneer this weekend. Was a bit concerned as I have never done this before.
Turned out to be quite enjoyable and not difficult after all.
Pretty pleased with the end product. Next step the clear.
Nice work!
DRUMMOND
Post by DRUMMOND »
Nice work looks great. make sure you use a marine grade clear!
pwilliam
Post by pwilliam »
Are you satisfied with the fitment of the original panels in the new dash? I found the fiberglass dash geometry to be a bit off from the panels so I shaped them to the new dash. Do I see toggles where the amber lights go? And if you don't mind my asking, how much does it cost to re cover the dash?
