Single Plane Manifold?
FLGordie
Your car is a: 1980 Fiat 124
Post by FLGordie »
Is this the desired manifold to use for to upgrade a 1980 Fiat Spider?
fiat218
Re: Single Plane Manifold?
Post by fiat218 »
Yes
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
fiat218
Post by fiat218 »
fiat218 wrote:Yes
It is a upgrade
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
FLGordie
Post by FLGordie »
Awesome. Will it cover all of the existing openings in the block or will I have to blank off an opening? I think I read in some conversions there is the need to blank off an opening.
bluespider262
Your car is a: 1979 Spider
Post by bluespider262 »
You need to deal with the egr passage. I pulled my exh mani, cut the tube, impacted the nut off, then plugged it with the correct size nut. I don't recall the size but got the plug off Amazon for a few bucks.
Warren
Post by Warren »
Hello:
If you will email me at whhopson@southernco.com I can provide some marked pictures of my manifold conversion.
Warren
Sylacauga Alabama
1979 Fiat Spider Automatic
1991 Alfa Romeo Spider Veloce
1974 Dodge Dart Sport Hang 10 (in restoration)
Multiple other cars, trucks, and boats
silvadw
Your car is a: 1979 Spider CS2 weber 34adf
Post by silvadw »
i used a welsh plug on the intake side of the head. left the exhaust side alone as i struggeld to get the nut loose. Took a while to get the correct size, 13.5mm from memory
various KTMs and V8's
RR Sport
'79 Spider 2000
FLGordie
Post by FLGordie »
You learn something new everyday.. I had to google welch plug. I was not familiar with the term. Wikipedia to the rescue. Welch Plug - "Core plugs are used to fill the sand casting core holes found on water-cooled internal combustion engines. They are also incorrectly called frost plugs, freeze plugs, or engine block expansion plugs." I grew up in the south. Very familiar with the term freeze plugs.
This was a great help. I got a picture off of the web and this makes perfect sense. Thanks for the help.
