So my signals work, but do not turn off automatically. I investigated thouroughly removing the wheel and column covers and here's what I find...
Turning the signals on and off lifts and lowers a white and black tab switch in the column. There is a brown ring with two fang looking protrusions at 10 and 2 o'clock. This ring spins FREELY around the column and if I turn either signal on will engage and turn off the switch in the column by hand. Nothing appears broken or worn, but since this ring freely spins it will never engage the tab switches on the column to turn the signals off. I have a feeling this ring shouldn't spin freely and rather should rotate with the steering wheel. Does anyone know what the problem is here and can offer advice to fix it? Pics of a functioning mechanism would be greatly appreciated.
Thanks!
Mike
How do I get turn signals to cancel?
- divace73
Re: How do I get turn signals to cancel?
there should be a pin in the steering wheel boss that engages that disc to turn it around.
Cheers David
see my >>You tube channel<<
Hmmm...so it should NOT spin freely?divace73 wrote:there should be a pin in the steering wheel boss that engages that disc to turn it around.
Anyone have a spare steering column that they'd be willing to spare this elusive pin from?
Upon inspection i see how this should work and go together. The pin is obviously missing. Likely the PO had an alignment done at a crummy shop or by himself which would explain why the turn signals don't turn off and while tracking straight the steering wheel is at 1 o'clock...
I fixed the pin and it failed again in a few years later. If I turn the wheel far enough it still works. So, I just know to cancel them myself. Its one of those things that makes me laugh about the car. kinda like when someone asks how I know witch way I'm turning because there is only one non direction specific turn signal in the dash. It adds to the flavor of the car. No AC, old fasion manual transmission, no anti lock brakes, no airbags, crankers, no reverse camera, one side view mirror. A huge smile every time I drive it.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
FIXED IT!...Creatively
. Since you can't really wedge something like a bolt in there without fear of it wobbling out (if you wedge it in, stands to reason it can fall out) I took another approach. I drilled a hole through the column on an angle to get down through the tab underneath that would hold the pin from above. The OD of the hole was slightly smaller than what I can only describe as a heavy gauge metal sleeve (like a tube about 2" long) that has a channel cut along it's length top to bottom. Imagine standing up a paper towel tube and removing a 1/4" slice top to bottom (much larger scale, but I hope you get the picture). It's one of the millions of left over parts from something I must have put together at some point. Since it has the slot in it I was able to wedge it in the hole from the top of the steering column and pounded it down, through the column into the slot in the plastic ring below that just spun round and round. It's in there SOLID, after a quick test drive it works perfectly, likely over engineered. I'm quite proud of myself
- seabeelt
- Patron 2019
Well done!
- Your car is a: 1977 Fiat 124
any pictures, i have the same problems , but i cant visualize what you did to fix it.
1977 Fiat 124 - Frankenstein engine
1999 VW Cabrio - Stock
1988 Fiero GT
And a couple of Daily Drivers
1988 Fiero GT
Sorry, i had it apart for 3 days and then the fix just came to me. I was actually surprised i could even drill through it, but that alloy in the column chips away like butter. From the inception of the idea to the test drive was about 15 minutesjagonza wrote:any pictures, i have the same problems , but i cant visualize what you did to fix it.
