Exhaust manifold torque specs ?
jagonza
Your car is a: 1977 Fiat 124
Post by jagonza »
Can some one please tell me the correct torque spec for the exhaust manifold nuts ? The ones that hold the manifold to the engine. For 1977 1800 with a 4-2-1 manifold.
1977 Fiat 124 - Frankenstein engine
1999 VW Cabrio - Stock
1988 Fiero GT
And a couple of Daily Drivers
Nanonevol
Your car is a: 1977 Fiat 124 Spider
Re: Exhaust manifold torque specs ?
Post by Nanonevol »
I'd like to know as well.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
"NUT, EXHAUST MANIFOLD TO CYLINDER HEAD STUD" 18 Ft-Lbs.
Nanonevol
Post by Nanonevol »
Thanks, Pete! Not that tight. Don't snap 'em!
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
This is from my '80 2L Shop Manual, but I think the risk is very low that it wouldn't apply to the '77 1.8L given the 4-2-1 manifold it shares in this case. And yes, it is a little low! I rechecked mine a few hundred miles later to be sure they were still tight. Same with cam boxes and head. Good idea to recheck after a few hundred miles.
jagonza
Post by jagonza »
wow i am glad that is way lower than i expected - it must tighten up as it heats and expands
1988 Fiero GT
aluminum head, iron header.... the gasket is a thick piece too. everything must move quite a bit, probably a common source of the clicking sounds that we all hear as things cool down.
