Trunk Lid Springs (removal)
spiderman1
Your car is a: 1982 Fiat Spider
Post by spiderman1 »
Anyone have a good technique for removing the trunk lid springs? I don't want to damage them and I am curious if there is an easy solution
Re: Trunk Lid Springs (removal)
They are tight as heck, but I was able to move them to a different position (3 position notches on the bar) by using a Big A$$ Vise-Grip pair of pliers on the spring end and pulling like crazy. It did scratch the paint on the spring a little, but it will do the trick.
use a wire coat hanger on the hook of the spring
bjbrown
Your car is a: 1980 fiat spider 2000
Post by bjbrown »
Now, the question is: how to re-install them without scratching the paint?
Boise, Idaho
1980 Spider 2000 EFI
1972 Sport Spider 850
touch it up afterwards..... :roll: :mrgreen:
bluespider262
Your car is a: 1979 Spider
Post by bluespider262 »
If you remove the plastic cover you can probably crack the trunk about half way and use the penny trick - shove pennies/coins in between the coils until you've got it mostly full, then open the trunk the rest of the way. The pennies will keep the spring from compressing again when you open the lid and you should be able to unhook it then.
