One day I noticed bubbles forming in the fuel filter after returning from a drive, with the engine turned off. It occurred to me that the fuel was leaking back into the tank as the car sat, which indicated to me an air leak, probably at the loose barbs.
I had another 32ADFA available that had "tight" barbs, so I made the swap to this apparently good top plate, which solved the cold start problem. After a couple of weeks, however, I noticed that the fuel was once again draining out of the filter, although not as badly/quickly, and the barbs had loosened up such that I could once again wiggle them with my fingers. In the time since the original swap the barbs in the "old" top plate now felt tight again.
So, I have replaced the top plate, once again, this time with one which has been modified to use threaded hose barbs. Hopefully, this will solve the problem once and for all. While discussing this with Ray and Lori Mortensen at Performance Apex, Ray informed me that the SCCA had mandated this modification on their race cars and Lori added that when there was a news flash in the '70's about a burning car on the freeway, it was often a Fiat where the barb had come out of the carb. I actually had that happen to me once, but was fortunate enough not to have a fire. Something to keep in mind, and it's easy to check by reaching under the air cleaner to wiggle the barb. If it moves, it's loose, and if you experience cold starting issues, check the barbs. All the best!
Original top plate
Modified top plate
