What is that noise at 3000 RPM......
NSFIAT
Your car is a: 1981 Pininfarina
Re: What is that noise at 3000 RPM......
Post by NSFIAT »
Are you using the plastic / rubber air flow boot or a metal one? If I can make do without the shield I'll toss it .....
NSFIAT wrote:Update - heat shield was the issue. Pulled it off and went for a quick drive before things got too hot. Are there any aftermarket options or photos of shields that others have fabricated?
The Exhaust Manifold heat shield or the CatCon heat shield?
NSFIAT
Post by NSFIAT »
Exhaust manifold - didn't hear anything after that was removed. Bolts were tight so I'm not sure how / why that was happening.
It has a second layer on its underside with the insulation. Probably a separation between the two layers?
burlyb
Your car is a: 1982 Fiat Spider 124 2000 FI
Post by burlyb »
Thought I'd contribute to this thread. I've been having a rattle on my '82 at 3000 rpm emanating from the passenger side of the engine. Checked the metal guard behind the timing belt cover (rattled), heat shields (no rattles), splash guard under engine (rattled) and isolated any contacts with engine accessories. Finally found it by noticing that my downpipe (4-2-1 installed by the PO) contacted the block. I loosened the stabilizer bracket and reefed on it and pried a small gap and re-tightened the bracket. All quiet now, so I go back to obsessing over the dash rattles...
