external door handle key
1983Pinin
Your car is a: 1983 Pininfarina
Post by 1983Pinin »
Hello,
I've been working on my doors since my locks have never worked. With enough time, liquid wrench and WD-40 I now have the driver side door opening when locked, and locking nicely using the key.
On the passenger side, while it will lock from the inside, I can not get the key to turn in either direction . It goes in nicely but just won't turn.
Before I try pulling the door handle off to work this out, is it possible that a door handle replacement would give this same result?
Would a Fiat door key go into the handle but not turn if it was not the right key?
I don't want to get into this only to find that I need to buy new handles to get a consistent key. And if I needed to do this, what do I do for the trunk lock, which is the same as my exterior door handle key.
Thanks for any input
--Peter
--Peter
1960 something 850 Spider in 1974-1976
1970 something 124 Spider 1977-1980
Currently 1983 Spider 2000
Ptoneill
Re: external door handle key
Post by Ptoneill »
You can buy a set of three lock cores from various vendors.. Or just leave the car unlocked and don't leave valuables in it......if they really want in they just cut the fabric top
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
klweimer
Post by klweimer »
+1 on not locking the car. What's the point? Also, it's entirely possible the two door keys are different. My car has a different key for each door and the trunk.
Kirk
