Speedometer Issue
pwilliam
Your car is a: 1972 124 Sport Spider
Speedometer Issue
Post by pwilliam »
Bought a replacement cable as the end of the old one was mangled and speedo was not functioning. Instead of replacing the whole thing, I simply withdrew the old cable portion from the sleeve and slid the new one in. I compared them in length to be sure, the new one from AR was about 1/8th of an inch longer. It seemed like the cable seated very easily and also slid into the speedometer well. I tightened the nut on the back of the speedometer as tight as it would go, but my speedometer still does not function. I also tested to see if the cable would spin in the speedometer when it was out of the car, and it did although there was some resistance.
Any ideas what could prevent the speedometer from working? I suppose its possible that the cable didn't full seat in the gauge but given i tightened the nut all the way I'd think that it did. Out of ideas on my end.
Thanks,
Pete
bradartigue
Re: Speedometer Issue
Post by bradartigue »
pwilliam wrote:Bought a replacement cable as the end of the old one was mangled and speedo was not functioning. Instead of replacing the whole thing, I simply withdrew the old cable portion from the sleeve and slid the new one in. I compared them in length to be sure, the new one from AR was about 1/8th of an inch longer. It seemed like the cable seated very easily and also slid into the speedometer well. I tightened the nut on the back of the speedometer as tight as it would go, but my speedometer still does not function. I also tested to see if the cable would spin in the speedometer when it was out of the car, and it did although there was some resistance.
Thanks,
Pete
If you remove the speedometer and drive the car does the speedometer cable spin? If not then it it either isn't seated at the transmission or the speedometer drive in the transmission is bad. If so then the speedometer is bad.
pwilliam
Post by pwilliam »
Good thinkin'! I'll give it a run this weekend.
DieselSpider
Post by DieselSpider »
If the cable end gets mangled then you have to fix what caused it to fail. If the cable spun easily in the jacket then that just leaves a potentially binding/defective speedometer to consider however if the old cable was bound up in the jacket the potential is fairly high that the speedometer drive in the transmission took a beating too.
spider2081
Patron 2024
Patron 2024
Post by spider2081 »
I saved a short section of the inner cable, about 1 foot. I can test a speedometer with it and a drill. the cable has to turn counter clockwise for the speedometer speed to increase. use a variable speed and start off slow and it doesn't take a lot of rpm to peg a working speedometer.
pwilliam
Post by pwilliam »
Good call!
Thats how i got my motorcycle speedo working again, unfortunately i am short of a drill at the moment! Always somethin'....
hifijoe
Speedo cable unhooked
Post by hifijoe »
Speedo cable came unhooked as i was taking my dash apart. Any easy way to re-connect ? My hand cant seem to reach to re connect and im having a hell of a time trying to get it on there again.
