These may help solve an issue that I'm having with the front openings. The painter masked around the openings instead of back taping, so there is an exposed primer edge that these may cover. If you have them, can you take a picture of how they cover the openings?
http://www.vickauto.com/newstore/index. ... ts_id=2481
Also, any feedback on the VAS brackets for these, to adapt to my 74.
http://www.vickauto.com/newstore/index. ... ts_id=3416
Abarth Bumperettes?
- Yadkin
- Your car is a: 1974 Spider
Re: Abarth Bumperettes?
What about your 1974 bumper?
Much better than the later ones.
1974 124 Spider
1964 500 D
2012 500 Sport
1948 Ford 8N tractor (restored (don't drink and ebay))
1964 500 D
2012 500 Sport
- Your car is a: 1985 Spider
I'm out of town and don't have a pic. The rear bumperettes cover the holes, but the front do not. I bought and installed Tony Miracle's bumper hole blanks, then cut out for the bumperettes and had them painted with the car. Another option would be to leave these blanks black.
Mark had at one time a fiberglass(?) bumperette that looked a little wider than the Abarth, so that would probably cover the entire front shock hole. I have also seen pics of people using Porsche 914 bumperettes, but they seem a bit large for my taste.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
73-74 had very strange bumper mounting, I don't think anybody makes a kit to mount Abarth bumperettes on those.
- Yadkin
Yes my bumper has a strange mounting. Remember that in 1973 GovCo required 5mp impact bumpers. So for my 73, the bumpers stick out about 5 or 6 inches, mounted by basically a long bolt, head welded to the frame and sticking out horizontally. There is a hard foam block that is part of the assembly, an energy absorber. My front blocks were a mess because the bolt rusted out, so I made replacements out of foam plastic trim lumber.
- Yadkin
To avoid having to paint the front of the car again.mscafide wrote:What about your 1974 bumper?
My front one looks nearly new, I suspect it was replaced at one time. My back bupers have some rust on the tops, so I masked off the tops and painted them silver. I'm not sure that I can buy just the rears.
Plus the mounts are post '72, stick out fro the car and look rather silly.
Yes, my 74 was the same. I had to make a bracket to mount it to the post and move the bumper closer to the body.
The front is now too close and I need to adjust it a bit more.
1974 124 Spider
1964 500 D
2012 500 Sport
1964 500 D
2012 500 Sport
- Yadkin
Nice. Do you have to lower the front too to make it fit?
