Distilled vs de-ionzed water
AriK
Post by AriK »
Time for a coolant flush. The local auto parts only sells de-ionized water. Opinions online (not here) are all over the map. Does it really make a difference?
Also, does mixing two brands of green coolant (bits leftover in my garage) really a no-no? Most of it would be Prestone, the final parts, bleeding process, topping up, etc. would be STP.
rjkoop
Re: Distilled vs de-ionzed water
Post by rjkoop »
AriK wrote:Time for a coolant flush. The local auto parts only sells de-ionized water. Opinions online (not here) are all over the map. Does it really make a difference?
Personally for the minimal cost I wouldn't mix 2 types of coolant but what do I know... :?
I bought deionized water from Loblaws but I think Cdn Tire has it as well.
Richard
aj81spider
Post by aj81spider »
My local supermarket sells distilled water. You might check there.
A.J.
2006 Corvette
vandor
Post by vandor »
I've mixed green coolants many times without any issues.
DieselSpider
Post by DieselSpider »
Bigger issue to me is how long has the coolant on which the seal has been broken been sitting on the shelf.
Always start off after a coolant flush with fresh and new is how I look at it.
