Fiat dies when I hit a bump!
priesterd
Your car is a: 81 Fiat Spider
Post by priesterd »
My 81 Turbo spider bogs down and dies when I hit a bump or rough road.
I have changed the fuel filter and checked the connections to the fuel pump.
Help!
lglade
Re: Fiat dies when I hit a bump!
Post by lglade »
Loose wire someplace. You might park somewhere where you can let the car idle and start wiggling wires until you can hear a change in rpm.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
124JOE
Post by 124JOE »
have you changed the battery lately?
i had a similar problem
it was the battery connections
so check there first
give each wire a good tug
if it comes off thats it
narfire
Post by narfire »
Ok my .25 worth... have a peek under the dist. cap as well. Wires in there get brittle and will give grief if frayed and car will stop if broken..
I had same issue once with poor battery connections as well.
joelittel
Post by joelittel »
Connector between the ignition switch and the harness. Mine was lose and had similar symptoms.
