Door Hinge
jagonza
Your car is a: 1977 Fiat 124
Door Hinge
Post by jagonza »
So i noticed a crack in my door hinge support, oh no! I took the door off and opened up the door jamb. worse than i thought.
Any advice - i will see if the tears / cracks can be welded up, but i was wondering if i put in a backer plate ( not welded in just as a big washer basically) if that would help going forward to distribute the stresses.
Any welders out there that can give me advice on if welding the corner up will yield good results ? Or should i look for a new door?
Any advice / coaching is appreciated.
1977 Fiat 124 - Frankenstein engine
1999 VW Cabrio - Stock
1988 Fiero GT
And a couple of Daily Drivers
SoFlaFiat
Re: Door Hinge
Post by SoFlaFiat »
Looks like you have opened up the area so weld it all up and it will be good for a long time. Its a common sight and I think these hinge supports cracked more from people leaning on open doors than anything else.
jagonza
Re: Door Hinge
Post by jagonza »
thanks SoFlaFiat, i checked out your blog, it really helped me to see that you had a similar issue.
do you think i need to add the plate that your added, or will it be enough to weld up the cracks, i cant think of an easy way to reinforce the edge that tore open top to bottom.
1988 Fiero GT
124JOE
Re: Door Hinge
Post by 124JOE »
the weld should be fine as long as nobody is hanging on the doors any more
jagonza
Re: Door Hinge
Post by jagonza »
1234Joe Thanks that helps me, i have found a welder and hopefully take it in next week
1988 Fiero GT
4uall
Re: Door Hinge
Post by 4uall »
you may also want to ask steve how his went
http://www.fiatspider.com/f15/viewtopic.php?t=26947
jagonza
Re: Door Hinge
Post by jagonza »
thanks i sent him an email just now
1988 Fiero GT
SoFlaFiat
Re: Door Hinge
Post by SoFlaFiat »
jagonza wrote:thanks SoFlaFiat, i checked out your blog, it really helped me to see that you had a similar issue.
The plate was only necessary because mine looked more like Steve's. Yours on the other hand doesn't look so bad. If you weld up all the cracked areas, it should be fine.
Best of luck!
DRUMMOND
Re: Door Hinge
Post by DRUMMOND »
make sure the matching hinge on the fender wall side is not cracked also. they both usually go at the same time
jagonza
Re: Door Hinge
Post by jagonza »
so i go the door back from the welder and spent three hours last night trying to get it aligned. I gave up for the night and will try again tomorrow. one millimeter either way is huge with this thing. i will take any advice.
I had an issue closing the door before i fixed the support, i was hoping it would be better after the repair but worse now.
1988 Fiero GT
AriK
Re: Door Hinge
Post by AriK »
I had sweat it out installing the door by myself while being careful not to ding the paintwork. Aligning it was the same story. If you don't do this procedure often it really helps to have a second person or third hand to help you out.
Basically you need to keep the retaining bolts just tight enough to hold your door in place & operational for testing and loose enough that when you unscrew one bolt per hinge you can budge the door by fist bumping it.
Finding that fine line can be frustrating.
SoFlaFiat
Re: Door Hinge
Post by SoFlaFiat »
AriK wrote:I had sweat it out installing the door by myself while being careful not to ding the paintwork. Aligning it was the same story. If you don't do this procedure often it really helps to have a second person or third hand to help you out.
+1
A true test of patience this is!!!
jagonza
Re: Door Hinge
Post by jagonza »
Thanks guys , finally got it done !
I wont admit how many hours it took, i had to call a few timeouts to keep me from reaching for the sledge hammer.
Now onto the next project - the exhaust system !
1988 Fiero GT
jagonza
Re: Door Hinge
Post by jagonza »
here are some more pictures to hopefully help the next guy
the welded hinge
the hinge with the backer plate inserted and weld coated with rust preventer
how i transported the door to the welder - he welded it while inside
back on the car - the blue tape save many many potential scratches
1988 Fiero GT
