Part Identification Assistance for Weber 34ADF
- howelljd
- Your car is a: 1980 Fiat Spider 2000
I need help obtaining a replacement part for my Weber 34ADF carburetor. I was fortunate to locate a used Weber 34ADF online for a great price. I had to drill out the bolt holding the water activated choke mechanism but I successfully installed a heli-coil to repair this issue. I cleaned it up and replaced the gaskets, O-rings, pull-off choke diaphragm, accelerator pump diaphragm, auxiliary pump diaphragm, and idle solenoid but there is a damaged part that I need to replace and I am unable to identify the part:
This appears to be an air mixture adjustment screw but it is buried in the throttle body under the carburetor body:
It appears to meter air through the secondary venturi above the throttle plate and via the manifold:
This screw is M5-0.8 x 9mm threaded with a 3mm diameter x 5mm long barrel that then tapers to a point over the next 7mm.
Thanks for any help identifying this part or providing a suggestion on how to proceed.
Cheers,
Jonathan
PS: I updated the measurements as I made an error earlier. The barrel of the screw is 3mm not 3.5mm.
Cheers,
Jonathan
Jonathan D. Howell, CSEP, PMP
Lieutenant Colonel (USA, Ret)
1980 Fiat Spider 2000 "Pini"
- howelljd
Re: Part Identification Assistance for Weber 34ADF
I was able to get a machinist to fabricate a replacement for this part. I've re-installed it in the throttle body by seating it and then backing off 1-1/2 turns as this seems to be a good starting point for air screws. Of course, since this screw is not an easily adjustable item, I remain interested if any others have encountered such a screw in other Weber 34 ADF 54 250 2M carburetors. I will be using this 34 ADF with a Computronix EDIS.
Hope to hear any feedback!
Cheers,
Jonathan
Cheers,
Jonathan
- Nanonevol
Well, that's interesting. I'm studying my 34ADF and mine lacks that's feature. I see other differences too.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- howelljd
I do find it interesting! The thought had previously crossed my mind that perhaps there were various throttle assemblies that could be swapped but I haven't found any documentation to support this theory. The differences for manifold vacuum are easily visible. There are also pathway differences and the unusual "L-shaped" block in my throttle assembly. My 34ADF came from a Fiat 131 based in Europe. Thanks for your note and photo for comparison!
Cheers,
Jonathan
Cheers,
Jonathan
Just so happen to have mine apart for a rebuild...
Mine has the brass screw but it appears to not be adjustable as I am unable to unscrew it from the base. Not real sure what it does.
- Nanonevol
Here's the side with the stamp on mine. These are amazing contraptions.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- howelljd
@msjulian - do you have any history on the source for your 34ADF? That brass screw is not an easily replaced item so I encourage you to leave it alone. I was able to extract the screw - obviously with sufficient force - but when it started to come out of the throttle assembly I did not support the split barrel (an M5-0.8 nut would have done this very well) and the sides were deformed as a result. Could you get a measure of the distance from the top of the screw to the top of the throttle assembly with a micrometer possibly? That would help me to determine whether 1-1/2 turns out is sufficient.
These carbs are awesome!
Cheers,
Jonathan
Cheers,
Jonathan
I purchased it from a gent in Australia about 14 years ago. Can't remember what he told me it came off of. I can get a measurement for you this weekend.
- howelljd
Any chance you were able to get a measurement of how far the top of the screw is set below the top of the throttle assembly? Thanks for any help!
Cheers,
Jonathan
Cheers,
Jonathan
If it's from Australia it's probably from a 2l 131.msjulian wrote:I purchased it from a gent in Australia about 14 years ago. Can't remember what he told me it came off of.
Mick.
I should be able to get that for you tonight.
- seabeelt
- Patron 2019
IF you folks go to: piercemanifolds.com, they have on line diagrams and parts for each weber carb, or can get them
NO 34ADF diagram on Pierce Manifolds...
Mine is .0410 deep
Mine is .0410 deep
Mine is .0410 deep
Mine is .0410 deep
- howelljd
I have ordered many parts from Pierce Manifolds and while their diagrams are useful, the part I requested assistance with has eluded formal identification. I greatly appreciate the measurement to get a reasonable starting point with my custom replacement part.
Cheers,
Jonathan
Cheers,
Jonathan
