I have so many questions that come up while taking on this head swap. Thanks for your help.
Couple of current questions:
4-2-1, 80 FI 2L
I am pulling the head and have the exhaust manifold nuts (along with 4 studs) removed.
Is it necessary to fully remove the manifold from the 6-bolt downspout, or is there usually enough slop to fit a new head and exhaust gaskets, etc. in with the 4-2-1 manifold in place? (I was amazed at how easily the exhaust studs and nuts came off with a little penetrating oil.)
But 4 of the 5 studs came out with the nuts, only the front stud stayed in place and just the nut came off.
Removing Exhaust Manifold And Head Question
- 124JOE
Re: Removing Exhaust Manifold And Head Question
have you ever double nuted a stud before?
put a nut on but deep enuff to put on a second one then tighten them together
but not down to the manifold
then try to loosen the stud
hope this helps.joe
then you can leave the manifold alone
hope this helps.joe
- aj81spider
I pulled my head a couple of times leaving the exhaust manifold in place. There was a fair range of motion that let the manifold get pulled back from the head.
A.J.
2006 Corvette
2006 Corvette
Excellent, thanks for the help! I will pull that last stud and leave the manifold in place. The nuts and studs at the head came off easily, but the 6-bolt junction at the downpipe looks a lot more corroded in place. Not going to touch it unless I have absolutely have to.
Pete
Pete
