I am trying to do a compression test this afternoon to determine initial conditions before I rip the top end apart and install HP head, cams, etc.
What is the best way to temporarily disable the Computronix ignition (block mounted in my engine) so as to not cause any damage or safety problem?
Just disconnect the connector at the unit?
Thanks. (no guesses, please. I am guilty of guessing too much myself.)
Pete
Best Way Temporarily Disable Computronix Ign?
- joelittel
Re: Best Way Temporarily Disable Computronix Ign?
I disconnect the battery and unplug my computronix at the unit itself.... but now you've got me worried that I've damaged it.
With the key off, disconnect the harness at the coil
Thanks, Mark! Glad you monitor the forum and assist so much.
Pete
Pete
