Motor mount brackets - unsure which one goes to which side?
JohnMc
Your car is a: 1970 Fiat 124
Post by JohnMc »
I messed up - marked the bags that the brackets were in and then cleaned both at the same time - do not know which one is which?
They are different and cannot find which one goes to which side.
Can someone help me out with photo or explanation as to whether they are to lean back or lean forward?
Thank you so much. John Mc.//
124JOE
Re: Motor mount brackets - unsure which one goes to which side?
Post by 124JOE »
i think they lean forward
ok i was wrong AGAIN
kmoses
Post by kmoses »
If yours have holes on the side, the one with two holes in the side of the bracket goes on the drivers side. The two holes are for the starter support bracket.
wizard124
Post by wizard124 »
Here you go:
JohnMc
Post by JohnMc »
thank you all!
