Water Pump Pulley fell off
BakersChoice
Your car is a: 1981 Spider
Post by BakersChoice »
Hey all,
Wonder if anyone has ever ran into this issue and/or could help me out. Was driving home today and the water pump pulley fell off while driving. I managed to recover the pulley and one of the bolts but I'm not sure what made it come so loose, maybe the bolts aren't right? The bolt I managed to recover is very short. Does anyone know the spec of the bolts that should be holding the pulley on?
Re: Water Pump Pulley fell off
The Water Pump Pulley Bolts (#M8x1.25) should be torqued to 17 ft-lbs, and probably a good idea to use Lock-Tite on them as well. Sorry, I don't know what their correct overall length is supposed to be.
BakersChoice
That chart is very helpful, thanks! I have one of the bolts and it looks pretty weathered (it has a little bit of rust on it) so I'm thinking it may be stock. I'm going to go by the local pacific hardware and see if they have them.
fiatfactory
Your car is a: 1970 128
Post by fiatfactory »
