Reverse Gear
- Your car is a: 1981 Fiat 2000
Reverse Gear
1981 2000. Are you supposed to pull up on the gear shift lever to engage reverse gear? RB'
- aevansgatech
Re: Reverse Gear
Push down ("in") and then over to reverse
1979 Spider 2000 (gone)
Re: Reverse Gear
I don't have to push down on my 82'. Never had to pull up.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
- FiatMac
Re: Reverse Gear
You have a stop that is miss-adjusted. There is a stop screw that adjusts to require that you push down on the gear shift lever (on all but the early models) in order to get into reverse. It is there to prevent inadvertent shifts into reverse. The early year models required that you pull the lever up. Someone else can chime in on the year the change was made.TX82FIAT wrote:I don't have to push down on my 82'. Never had to pull up.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
83 parts car
- spiderdan
- Your car is a: 1968 124 Sport Spider
Re: Reverse Gear
Agree, my 68 is a pull up.FiatMac wrote:The early year models required that you pull the lever up.
"all AC/AS and BC/BS were pull up for reverse.
all CC/CS were push down."
From
http://t124.com/forum/viewtopic.php?f=2&t=6870
Dan
"Angelina"
2015 Toyota Camry XSE (hers)
2016 Jeep Wrangler Sahara Unlimited (cottage toy)
http://s1342.photobucket.com/user/68spi ... t%20Spider
http://www.youtube.com/user/Coontache/videos
"Angelina"
Re: Reverse Gear
Thanks everyone for the answer. Shifting into reverse much smoother now. The owners manual is not specific on that. You would think they would be. RB
- Your car is a: 2013 Elantra Gt
Re: Reverse Gear
Sorry for posting to a three year old thread, but this saved me a ton of unnecessary work. I was thinking I was going to need to some work replacing the reverse gear, but all I needed to do was press down. I still have to drop the trans and replace the pilot and input bearings, but no digging into the gears.
Thank you, thank you, thank you!!!!!
- btoran
- Your car is a: 1975 Fiat 124 Sport Spider
Re: Reverse Gear
I've learned that keeping the trans fluid filled properly helps tremendously with shifting into all gears, especially reverse. That said it's not easy with the way they engineered it and no way to monitor it except to lift the car and get dirty underneath.
1975 Fiat 124 Spider
- Patron 2021
Re: Reverse Gear
I have to push down into reverse and also not shift directly to 5th, Always shift to 4th first, Tranny may need some work, When I go thru this routine the gears mesh,
Re: Reverse Gear
Since they started putting safety interlocks on the shift levers of manual transmissions there have been basically five choices:
I used to help a wholesaler deliver cars and we knew to check for the ring, button, spring, up and then down. It becomes rather obvious after a while which one your dealing with in the current car and you don't really even have to think about it and just do it automatically.
- Pull up
Push Down
Push against the spring release firm but not hard to the right
Pull Ring
Release Button
