Is this the way transmissions usually look inside?
kmoses
Post by kmoses »
I just got around to draining the transmission and removing the bottom cover plate. I was surprised to find everything so clean! Is this the way the manual transmissions usually look when you open them up? When I purchased the car it could not be driven so the last thing to do was check out the transmission. There was no steel in the bottom but there was some very fine brass. Would you go ahead and tear it down or close it up and install it?
BEEK
Your car is a: 1975 Spider
Re: Is this the way transmissions usually look inside?
Post by BEEK »
looks to me like the transmission was run low on oil, 4th gear on the layshaft has gotten very hot
75 spider
son has 78 spider
at a minimum I would see how much play the forks have in the slider grooves
kmoses
Post by kmoses »
Can I check it with a feeler gauge in the case? If so what is the normal range? The gear that meshes with the "dark" gear looks new and the teeth show very little wear. If it was run low on oil, would both gears be dark?
wizard124
Post by wizard124 »
It appears that there is a crack in one of the teeth.
I would continue the tear down and inspect.
GeorgeT
Post by GeorgeT »
The brass filings are most likely from worn synchros. Since you've gone this far you should finish the job by replacing them as well.
kmoses
Post by kmoses »
I went back and looked at the "crack" on the dark gear tooth, it is a thread from a shop rag. I was wiping that side of the gear trying to clean the teeth and see how rough the edge is. It looks like the very corners of the teeth on the inside were damaged but the faces are smooth with no galling. I'm thinking that this gear box has had one or two gears replaced. It looks like I will need to take it apart after all.
Frog2Spider
Your car is a: 1981 2000 Spider
Post by Frog2Spider »
There was a thread here recently about 'reliability'. This serves as a perfect example.
You could put the trans back in, the way it is. It could last 100 miles, a 1,000 miles, or whatever. But it will NEVER be reliable! And the worst part is that Murphy's Law dictates that it will fail at the most unoportune time!
Good choice to rebuild it and make it reliable.
Always looking for curves under blue skies!
Frog2Spider
'81 - 2000 Spider
BEEK
Post by BEEK »
to further my observation. The layshaft gear which meshes with 4th gear has been extremely hot. By looking at the unit i can assume that someone has been into the transmission and replaced the 4th gear but not the layshaft. better pictures will let me determine the shift fork condition. but unless you are able to tear the box down there is no way to assess the condition of the syncro's. How did you come by this transmission? again i can only assume it did not come out of your car. i have rebuilt 100's and yes i said 100's fiat 124 transmissions.
75 spider
son has 78 spider
kmoses
Post by kmoses »
This is the transmission that was installed in the car when I purchased it in May 2015. The couple I purchased it from owned it for 9 months and never had it licensed. It would start but not idle and if you pressed on the brake pedal, the car would shut off. They bought it off an Ebay auction and had it shipped from California to North Carolina. They decided to sell it and cut their losses rather than spend more money on it.
djape1977
Post by djape1977 »
shutting down when you press brake - needs a new brake servo
kmoses
Post by kmoses »
I checked the clearance between the shifting forks and sleeves; First/Second Sleeve and shift fork = .016" and Third/Fourth Sleeve and shift fork = .021" . The shop manual says to "check the shift forks for wear", does anyone know what the min./max. gap should be between ths shift forks and the sleeve groove?
Also, there are no wear marks at all on the input shaft gear or first gear faces. All of the gear teeth faces on the Countershaft/Layshaft show wear as do second and Third gear.
