AM I MISSING SOMETHING???
If the brake pads do not have anti-squeal shims on them then you need to use brake quiet instead. Most of the better grads of brake pads will include a packet or two in the box with the brake pads.jandarah wrote:Thanks again. I am not aware of this type silicone rubber spray, but will chase it up. As for the shock absorbers, again, I know nothing of their history, except that they are not original, but a brand that is the same as a company that does brakes here in Australia (and maybe other countries), Pedders.
If the brake pads do not have anti-squeal shims on them then you need to use brake quiet instead. Most of the better grades of brake pads will include a packet or two in the box with the brake pads.DieselSpider wrote:jandarah wrote:Thanks again. I am not aware of this type silicone rubber spray, but will chase it up. As for the shock absorbers, again, I know nothing of their history, except that they are not original, but a brand that is the same as a company that does brakes here in Australia (and maybe other countries), Pedders.
