Mine is also a retrosound
http://www.fiatspider.com/f15/viewtopic ... 74#p219174
What radio to install?
- Your car is a: 1972 124 Sport Spider
- toplessexpat
Re: What radio to install?
1000W amp hidden behind rear seats. Blackberry stereo gateway as it's only feed. Bluetooth from iPhone to gateway. Great quality sound, no head unit required, and "CarPod" is a great app for controlling the whole lot.
- Your car is a: 1981 FIAT Spider 2000
I also just installed a BlackBerry Gateway directly to an amp. So far so good, I still need to get 5 volts to the gateway from the car.
An in line controller is on the way to act as a manual volume control. Seemed like a good emergency backup.
My plan is to replace my head unit with a single din triple gauge trim to hold oil temp, pressure and volts.
I am sorry I let my LearJet in-dash 8 track stay with the last car I had installed it in. Very much like the OEM radio and correct for the time period. It was new and current technology when I bought it. I usually boxed it up when I changed cars but it was a relative who begged that I leave it in the car while he had it and he forgot that he promised to give the unit back when he sold the car.
- toplessexpat
I used one of these little modules to provide the 5v.burgandy81 wrote:I also just installed a BlackBerry Gateway directly to an amp. So far so good, I still need to get 5 volts to the gateway from the car. [snip]
http://www.ebay.com/itm/like/321643089409
As for the console - getting hold of a 124 Coupe one works well. Remove the air vents and you've got two 2.5" mounting pods.
A
- Patron 2024
