carb sync tool
Frankd1
Your car is a: 1978 Spider
carb sync tool
Post by Frankd1 »
I just wanted to double check that this is the correct sync tool to use for balancing twin IDF carbs, I have these on my 78...
http://vwparts.aircooled.net/Snail-Type ... ste-sk.htm
bradartigue
Re: carb sync tool
Post by bradartigue »
yep
Frankd1
Re: carb sync tool
Post by Frankd1 »
Thanks, I was just flipping through one of your pdf publications and I noticed that you mentioned there that the SK tool is recommended over the BK as well as the Uni-Syn gauge.
I will go ahead and order one of these
jandarah
Your car is a: 1977 124 Spider
Re: carb sync tool
Post by jandarah »
That is what I own and have used on my twin 40 IDF's. Work a treat and easy to use.
John in Oz
First Fiat: 1970 124 sedan 1970 - 1976
Then horse float towing vehicles up to present.
Current Fiat: 1977 124 Spider 1756cc with twin Weber 40 IDF's
1970 124BC coupe; 1756cc with twin Weber 40 IDF's, used for sprinting
Frankd1
Re: carb sync tool
Post by Frankd1 »
Just placed the order, thanks!
Frankd1
Re: carb sync tool
Post by Frankd1 »
My sync tool arrived in the mail, however, its not the "STE" brand that is made in Germany, grey in color.
It is a generic made in taiwan ste-sk tool, black in color with no markings on the plastic body....looks identical otherwise and it feels pretty solid. I just want to make sure that this particular tool will function correctly even though it is "generic" or a knock off. You know how it can be sometimes with tools that are knock off's of the original as far as calibration etc goes...
Anybody using this one?
Some pics:
sptcoupe
Re: carb sync tool
Post by sptcoupe »
That will work fine. You are just trying to be sure all the bores are flowing evenly (at the same rate) at idle. Just be sure it isn't somehow flawed and that it works consistently. Do that by measuring the flow on the same bore several times, a minute or so apart, when the engine is fully warmed and see if the reading is close to the same each time. I would be really surprised if it had a problem.
kilrwail
Re: carb sync tool
Post by kilrwail »
I agree. I have the STE model, available from Pelican Parts - a first class Porsche parts dealer. The absolute reading on yours may or may not be accurate, but it doesn't matter. As long as you get the same reading on both venturis, you're good to go.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Frankd1
Re: carb sync tool
Post by Frankd1 »
Thanks guys.
Just wondering what these brass tubes are that are sticking out from the carb barrels? 90 deg bend at the top and slightly pinched off? Wondering if the carb sync tool passes overtop of these tubes?
From other weber pictures I have seen I have not noticed these tubes before...
Picture with filter base plate in place:
without the base plate:
JerryH
Your car is a: 1976 124
Re: carb sync tool
Post by JerryH »
Those are high speed spray tubes. See the description here:
http://www.artigue.com/fiatcontent/carbs/40_IDF.pdf
Apparently some IDF 40 carbs don't have these. Mine do. In order to sync my carbs, I purchased a single 'velocity stack' so I could fit the gauge to the carb and clear these tubes. I used some thin weatherstripping on the bottom of the stack to form a gasket to prevent air leaks. I simply insert the gauge into the stack and hold it in place to make the measurement.
1976 Fiat 124
1972 Fiat 124
JerryH
Re: carb sync tool
Post by JerryH »
Here's a look at my carbs. Just like yours! Same K&N filters.
1976 Fiat 124
1972 Fiat 124
Frankd1
Re: carb sync tool
Post by Frankd1 »
Thanks Jerry, do you by chance know which velocity stack you are using? Where you got it from? want to make sure I get the right one
JerryH
Re: carb sync tool
Post by JerryH »
I'm pretty sure this is the one I purchased.
http://www.webercarbsdirect.com/product_p/129200.htm
I purchased my rebuild kits from them as well....
1976 Fiat 124
1972 Fiat 124
Frankd1
Re: carb sync tool
Post by Frankd1 »
Thanks Jerry.
With the velocity stack, will the carb sync tool plug right in using the rubber adapter as shown in my photos, or do you need a special adapter for the velocity stack?
JerryH
Re: carb sync tool
Post by JerryH »
It 'plugs right in'.
1976 Fiat 124
1972 Fiat 124
