1800 head to use with 2l block
BammBamm
Your car is a: 1982 Pininfarina Spider
Post by BammBamm »
I heard that not all the 1800 heads are desirable to use with a 2l block. Which one do i want?
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
bradartigue
Re: 1800 head to use with 2l block
Post by bradartigue »
Any one of them will fit. So will a 1592 head. IIRC the 1976 Lancia Montecarlo head has the largest ports by a couple of mm, so it may open up the breathing slightly (more air/more power).
I'm not sure what makes one or the other undesirable; the later 1800 heads had air pump connections, so you have to plug those holes if they aren't plugged already. Otherwise they're all kind of the same head.
BammBamm
Post by BammBamm »
Great to hear. Thank you. Do you know the value of a good 74 1800 head?
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
BammBamm
Post by BammBamm »
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
vandor
Post by vandor »
All US-sped 1800 head had the 4 ports for the air-pump manifold.
